Sold 1976 GMC C25 Crewcab $4000 - Grandpa
kennyw
@squarebody.chop.shop on IG
Stevens Pass Highway, WA
$4000 picked up in Sultan, WA.
This is a 1976 GMC C25 Crewcab in Serra trim. Overall in solid shape for the body with minimal rust in driver door and rocker. Another spot of rust on passenger rear wheel well. The hood is bent and I welded up the cracks to keep it from getting worse, but it locked in the bend, it could be reworked.
The engine is a good running Chevy 350 V8, TH400 automatic transmission, 14 bolt rear axle. The truck runs and drives and the brakes work like they should.
In order to get the truck roadworthy, I have replaced the fuel pump, carburetor, air filter, alternator, upper radiator hose, heater hoses, and battery cables. There may be other items needing maintenance soon as well, but these were the major ones to make it ready for a roadkill adventure. Although it is running off the gas tank so it may be nicer than a roadkill slightly.
