Chip Cross
Registered Member
For sale is my Jimmy with a GM 5.3 swap into the truck and I replaced everything from the fuel tank to the fuel rail on the motor with new parts. The fuel system is all plumbed in -06 Aeroquip socketless hose and -06 socketless fittings. I replaced the tank with a brand new tank and sending unit for a 1991 Jimmy and put the pump in the tank. I used a Holley/Walbro 255 LPH forced induction pump in the tank and a regulator/filter from a 99 to 03 Vette. I am the 4th owner of this truck and this truck is an original Arizona truck so there is very little rust on it at all. I have receipts for everything that has been done to this truck and it adds up to 27K. The only thing I don't have any receipts on is the axles which came from a 1986 CUCV with 28,XXX miles on it.
I just replace the radiator with a new one from Jegs I put a fan shroud and a 16 inch HD 2200 CFM E fan.
Radiator and E fan
The power steering and trasmission coolers are plumbed in -06 socketless hose and -06 socketless fittings.
Power steering cooler
Transmission cooler
Fan switch
Specs :
GM 5.3 from a 2006 GMC Sierra with 38,XXX miles on it
Motor, harness and PCM came from Pacific Fabrication<-- These guys are GREAT!
Street and Performance LS motor swap plates.
Fleabay cold air intake.... basically a 4 inch 90 a 4 to 3 1/2 reducer for the mass air flow sensor and a K&N clamp on with a outerwear. It is nothing fancy but it is good as a wet dream!
Hughes performance flex plate and Tq converter spacer.
Motor has mid length ceramic coated headers from Street and Performance
for a 5.3 swap into a 1973 to 87 GM Truck. I used a single Dynomax x flow muffler and no cats. The truck sounds great!
New Taylor 10.4 wires, Taylor plug boots and with Bosch Platinum plugs
Flushed out the engine when we swapped it in. All I have ever ran in the motor is 5W20 Royal Purple oil.
Truckshop Performance tune that really woke up this motor!
Two new Diehard batteries with a 100 month warranty that breaks down like this 36 month free replacement and 64 month pro rated replacement.
New hydoboost brake system complete from the brake booster to the rearend it stops great and drives like a Caddy!
The inside of the tub has been Line X'ed
3000 watt continuous 6000 watt max inverter
New 31 gallon fuel tank with skid and very nice rear offroad bumper
Dana 60 front
Lock Right
1/4 Diff Cover
4:56 gears
New rotors, calipers and studs
New Wheel bearings
King Pins reworked
2.5 inch BDS front springs
ORD HD grease able shackles
ORD sway bar dico
ORD Steering box brace
14 Bolt rear
Detroit locker
4:56 gears
1/4 Diff cover
U joint / yoke rock guard
Rear disc conversion
New bearings and seals
shock mounts moved
axle perches moved
4 inch BDS rear springs
Built TH400 just changed the fluid
6 bolt round adapter
6 bolt round NP 205
New bearings, gaskets and seals in the NP 205
Twin sticked with JKW shift rails and NWF cable shifter
New 17X9 Pro Comp 1069 wheels with new 36X13.50X17 Irok bias tires. The tires have 78 miles on them and measure out the same as a 37x14.00X17 Irok which is 36.8 inches. I also have a 5th matching tire but no rim for it they are on a national back order
I would drive this thing anywhere in the U.S. Since the motor swap I have put about 500 miles on the truck and it runs flawlessly!
I am asking $10,000.00 and price is firm.
I need this thing gone yesterday, I am fighting Kidney cancer and I am going to lose my job and insurance soon. I need to put some coin in the bank.
I would look at a trade + cash my way.
Radiator and E fan
Transmission cooler
Fan switch
Specs :
Dana 60 front
Lock Right
1/4 Diff Cover
4:56 gears
New Wheel bearings
King Pins reworked
ORD sway bar dico
14 Bolt rear
Detroit locker
4:56 gears
1/4 Diff cover
shock mounts moved
axle perches moved
6 bolt round NP 205
