Would a 14 bolt rear on the 77 camper special 2x4 be a 14 bb full flooter? What gearing would it have?
if swapin in to a 4wd truck will require swapin the shock mounts around.
Not really, you'll just have one if i remember right, the driver side that the body of the shock will be right up against the axle tube. I have been running mine like that since i got it, about 5-6 years now.
The u-joint will need a conversion joint as well, going from the 3/4 ton yoke to the 1/2 ton driveshaft.
I'm planning on buying all new driveshsfts after I lift it and swap axels. So it is best that I find the axels from a 4x4.
