JS1977K10
Newbie
I was in 4 wheel drive and after taking it out of 4 wheel, The engine seemed to bog down. I put it into park and heard some sounds. TH400 that was functioning fine, but now suddenly it will not go from Park into any gear. Behaves as though it's in neutral...
I can move the shifter freely if the linkage is not hooked up to the transmission. So I don’t think its in the steering column. It has transmission fluid. I can start the truck just wont go into gear once its running. Shift arm wont move from park to any gear.
