Still in my 77 K5 with 160k well cared for light use miles {think old man fishing rig}. If the weather is good I will be pulling them out on 2-23-19. $275.00
Would you sell the pedals separate?Bump
I can include clutch/brake pedals along with all of the clutch linkage, $300.00 buys everything. Still in vehicle {for now} can video/demo.
I have a set of mechanical pedals from my sons 78 K10 I parted out. About the same year and mileage and already removed and ready to go. $30.00 picked up or plu$ the shipping.Would you sell the pedals separate?
Assuming mechanical not hydraulic.
This one seems to be in great shape, I only wheeled with it once and it worked fine. Previous owner never wheeled it hard judging by the looks of my K5. I put fresh fluid in both right after I bought it, old fluid looked good.I dont know much about the 465's. I have a kid who helps me who is looking for one for his 71 truck.
77 205 would have the 10 spline input and 30 spline front output along with 32 spline rear output.This one I believe if original is 10 spline input and 10 spline output as well, lots of smarter guys then me here though.
Input anyone? @Bent77
If you take it apart you can ship it in a much smaller box and I can put it back together blind folded.I have a set of mechanical pedals from my sons 78 K10 I parted out. About the same year and mileage and already removed and ready to go. $30.00 picked up or plu$ the shipping.
I will keep my eyes open. I assume you can use one of these for an underdrive/gear reduction because of the larger input?I actually would like to find one, they came in c50, c60 medium duty trucks with a drum brake on the output for ebrake
It has the same diameter as a 10 spline old sm465 but slightly different angles on the splines.I will keep my eyes open. I assume you can use one of these for an underdrive/gear reduction because of the larger input?
If Ron don't have a set by the time you come this way, let me know. I've got the same setup out my 75 K5 I kept and now that I committed to the big block 4500 route, I'm tripping over them in my garage. Worked fine, now clean. Just need seals. I'll even throw in a second shifter. Im a couple hours south of Ron.It has the same diameter as a 10 spline old sm465 but slightly different angles on the splines.
I can double up on transmissions and not worry about breaking the input on the second. It would be good for the crew cab, enough length to work.
You have a medium duty sm465?If Ron don't have a set by the time you come this way, let me know. I've got the same setup out my 75 K5 I kept and now that I committed to the big block 4500 route, I'm tripping over them in my garage. Worked fine, now clean. Just need seals. I'll even throw in a second shifter. Im a couple hours south of Ron.
No. The same setup Ron has. 75 465 10 spline output and matching 205 with the adapter.You have a medium duty sm465?
