1AAuto.com
Click here for current pricing...1978 - 1991 Chevy Suburban Spindle and Bearing Repair Kit set for 4WD Models
This front spindle and wheel bearing repair kit set is just what you need to repair noisy and bad bearings inside the spindles and rotors of a GM 4x4 truck. The kit contains enough pieces to repair both sides of the truck.
If you need to repair one side, the other side is probably not far behind on needing to be repaired also. So why not do both sides now before you are stranded on the side of the road with welded hubs and spindles!
The bearings and seals are new aftermarket replacement parts that have the following specifications:
Enough pieces to repair both the LH Driver and RH Passenger Side
The front spindle inner bearings and seal kit includes:
Qty (2) - High quality inner spindle/ axle shaft bearing
Qty (2) - Inner spindle oil seal
Qty (2) - Inner spindle washer
Qty (2) - Spindle to knuckle flange seal
Qty (2) - Spindle to knuckle oil seal
The outer wheel bearing sets includes:
Qty (2) - High quality outer wheel bearing
Qty (2) - High quality outer wheel bearing race
The inner wheel bearing sets includes:
Qty (2) - High quality inner wheel bearing
Qty (2) - High quality inner wheel bearing race
Qty (2) - Inner wheel bearing rotor dust seal
Replaces one of many dealer part numbers including: 457232, 9437512, 6273948
Direct bolt on replacements
Seal and bearings are built to strict quality control standards
Note: For 1977 models, to determine if your vehicle was built in late 1977, the inner wheel bearing will be stamped with either LM104949 or JLM104910, or possibly both: LM104949/JLM104910. This means that the inside diameter of the bearing is 2 inches. If the inner bearing is stamped with 368A or 362A, this mean that the inside diameter of the bearing is 1 25/32 inches and it is an early model. This kit will not fit the early 1977 built models.
