Local pick up in Sultan, WA. This truck will make a good work truck with a little more work or the occasional dump run as-is. Clear title. Asking $2250 on Facebook, $2000 here to a CK5 member.
Runs and drives very well
350 V8 motor
TH400 automatic transmission
New carb w/ electric choke
Fresh tune-up (cap, rotor, plugs, and wires)
New brakes (pads, turn rotors, drums, shoes, calipers, slave cylinders, master cylinder, and booster)
Good tires
14FF rear axle
The body has dents, rust, and a bent hood. Windshield needs to be replaced. Dash lights and some gauges are not currently working.
The floors and rockers are very solid so you won't lose anything out of the bottom driving down the road. Aftermarket mesh tailgate works. The grill is in very good shape.
350 V8 motor
Good tires
14FF rear axle
