1978 K20 Suburban Scottsdale 4x4
This is likely to be the cleanest most well kept K20 Suburban you will ever find. It was purchased from the original owner with just 60,000 miles. The previous owner purchased the vehicle new and I have the window sticker, build sheet, and service manual. The factory engine has been replaced with a very nice 454. The 454 features MSD ignition, Edelbrock intake, Hedman headers, and a quadra jet carburetor. The motor runs like a top. A mild RV cam and dual exhaust give it a throaty hot rod sound. The drive train also consist of a perfect combination of a SM465 manual transmission with deep low, NP205 part time transfer case, and front and rear heavy duty differentials to be verified. If you know anything about four wheel drive vehicles you are aware that this is a bullet proof set up. The transmission and transfer case shift flawlessly.
The suspension has just been replaced with a full leaf spring and shock set from Tuff Country. The vehicle has been lifted 4" to accommodate brand new 35" Yokohama AT tires. The factory wheels have been powder coated black and the hub caps remain in perfect condition. The exterior of the truck is in beautiful condition. All trim pieces are present in excellent condition. The bumpers and grill look as good as new. The paint appears to have had one re-spray with no rust what so ever. The truck was originally from a dry climate in Washington State. The paint shows just enough use to be able to use the vehicle but shines nicely and reflects no prior body work or damage. The interior is in immaculate condition. The truck features 1st and 2nd bench seating with no third row present. The dash is not cracked, the original radio is working, the seats and floor coverings are as new. This is a true 60,000 mile vehicle used for recreational purposes its whole life.
The truck drives great. It turns a comfortable RPM down the interstate with the addition of the larger tires. The steering is tight, the doors shut nicely, and there are no rattles or squeaks. The under carriage is clean as a whistle with no leaks. This is truly an amazing vehicle and needs absolutely nothing. It is ready to be enjoyed.
http://s101.photobucket.com/user/rockint/media/78motor_zpsc62a14f7.jpg.htmlhttp://s101.photobucket.com/user/rockint/media/78motor_zpsc62a14f7.jpg.html
its hard to read atthat size also .
