1979 C-10 cab and rolling chassis
dpmalibu
Trenton,NJ
All that is left is front and rear suspension.There is no bed. Has gas tank still on it. Rear springs are 3/4 ton springs (8 leaf). 12 bolt rear w/ 2.76 gears(non posi)
has a 305 long block still in it. Cab is about 95% solid. Only has small rot hole on inner rocker panel and pass. side floor support. Rest is solid .Still has glass.Does not have doors, seats, steering column. I want $250 and you bring your own tires to put on it. I may keep the rear springs and rear if I do I'll let it go for $200.Good for somebody with a very rotted cab. Has PA title. Located in Trenton,NJ (609) 481-8811
