1979 cab on 1989 1ton frame?
nocoasthardcore
Colorado
I am wanting to put together a pickup, I have a 77 cab that is in decent shape and my uncle has the frame and running gear from a 1989 V3500. Will this cab bolt onto this frame? Thank you.
need front clip also from 80-and back unless you want to mod lots of stuff to fit 81-up front.
and possible floor pan work in tranny tunnel area or swap out of the bolt in style.
other than that direct bolt on. only thing is use body mounts for the year of the frame not the cab.
i have a 87 cab on my 79 frame.
So I will be needing the cab mounts for the 89 frame, not for the 77 body?
Thanks for the reply.
