maddog_blazer
Newbie
Hello Out there in 4x4 land, I have a small problem I wondered if someone could help pinpoint a noise I recently came across after hooking up my Chevy k-10 which I converted from 1/2 to a pair of 3/4 ton 373 axles front axle being a 10 bolt and rear being a 14 bolt corporate being pushed by a sm465 and np205 transfercase. It seems after placing on my newly rebuilt front driveshaft and giving the 4wd a spin around I noticed a clicking noise when I engaged it from 2wd to 4HIGH. now this truck was an auto and had to drop a hole in the floor for the shifter on the sm465 to be mounted and I noticed the np205 when your engaging the shifter from 2 wd to 4 high wd tends to bump the shifter linkage against the hole on the floor where the 4wd transfercase shifter is located so Im wondering before I take another look if the transfercase isnt being pulled all the way back and is being held back before completely engaging would that be a sypmtom for the clicking noise Im hearing which sounds like its eminating from the transfercase. Any advice on this please feel free to assist this amateur. Thanks a TON
