Tonyraca
Registered Member
Well the time has come to part with my project rig. I just got a new '72 Jimmy so the Blazer has got to go. I've got a few pictures and can take more upon request for anyone seriously interested.
Where to begin...She may not be the pretties rig, but there is some serious power under the hood. The best part about this truck is the engine. It's a 383 Stroker custom built by Eddings Engine in San Fernando California. Dyno'd with 330HP and 395ft.lbs. at the crank. I've given some unsuspecting BMW drivers a run for their money at traffic lights.
This truck has passed full California Smog testing multiple times and is currently registered through Aug 2012. For those of you in California you know how much a truck that can pass smog is worth. Truck is located in San Jose, CA
I'm looking to get $4,000 OBO for everything listed here. May trade for street, touring, or dual-sport motorcycle
The list is long and the pictures are at the bottom.
I am not interested in parting the truck out at this time. This is a great project for someone who has the time to put everything together.
383 Stroker Motor built by Eddings Engine San Fernando, CA
This engine Dynoed at 330HP and 395ftlbs
I've got all the recipts for this engine + Recorded Dyno runs after the build and tuning. There's over $7000 invested in the engine alone and more than $5000 in other parts.
Start with 350 4-bolt Main
add 383 Stroker Kit
- Scat 4340 Crank
- Scat H-Beam Rods
- Ross Pistons
- Cloyes True Roller Timing set with Timkin bearings
Fel-Pro Gaskets with performance head gaskets
Melling High volume Oil pump with drive
Crane Gold Race Roller Rockers
Manley Chrom Moly Push Rods
Comp Cam 12-249-4
Sealed Power Lifters
Edelbrock Performer EGR Intake
Edelbrock Performer Cylinder Heads
Edelbrock Performer EGR Carb 1406
Edelbrock EGR Adapter
Edelbrock Performer Fuel Pump
EdelBrock Stainless Braided Fuel Line
Russel Fuel Line and Filter Kit
JEGS Billet Aluminum Throttle Bracket
ARP Main Studs
ARP Head Bolts
ARP Oil Pump Stud
ARP Balancer Bolt
ARP Flexplate Bolts
ARP Stainless Accessory Bolt Kit
ARP Fuel Pump Pushrod
ARP Starter Bolts
Milodon Oil Pan
Milodon Pick-Up Screen
Pioneer SFI Flexplate
Pioneer SFI Race Balancer
Aluminum Timing Cover
GM Aluminum Valve Covers (Wrinkle Finish Black)
Drivetrain:
Rebuilt TH350 Transmission
TCI Cast Aluminum Deep Transmission Pan 6qt
NP-203 full time transfer case
Auto Meter Pro-Comp 5" Tachometer
Auto Meter Pro-Comp 5" Speedometer (160mph with resettable trip odometer)
Auto Meter Speedometer Sender
Auto Meter Pro-Comp 2 5-8" Water Temp Gauge
Auto Meter Pro-Comp 2 5-8" Fuel Level Gauge
Auto Meter Pro-Comp 2 5-8" Volt Meter Gauge
Auto Meter Pro-Comp 2 5-8" Oil Pressure Gaute
Flex-a-Lite Dual 13.5" Electric Fans
Replacement Stock Radiator
Dual 2.5" Exhaust with
Dual Flowmaster Hushpower II 2.5" Mufflers
Dual Dynomax 2.5" Catalytic Converters
Heddman Headers with A.I.R. Injection
MSD 6AL Ignition Controller
MSD Blaster 2 Coil
MSD Pro Billet Distributor with Vacuum Advance 85551-8361
MSD Chevy Starter
GM Performance Parts Serpentine Belt Accessory Drive Package w/AC and 105amp alternator.
Air Conditioning system is not complete and the heater core is not currently hooked up.
Painless Performance 18 Circuit GM Truck Wiring System
Dual 2 1/2"Exhaust
Dynomax #289-15142 3-Way Super Catalytic Converter In/Out: 2.5" Length: 18"
Off Road Design - High Clearance Engine Crossmember
Off Road Design - Competition Style Motor Mounts
Off Road Design - 1" Body Lift Kit
Energy Suspension Poly Body Mounts
Off Road Design - 1" Zero Rate Add a Leaves
Off Road Design - Greasable Rear Suspension Bushings
Off Road Design - 2 1/2" Reaf Shackle Flip Kit
Off Road Design - Heavy Duty Front Shackles with Greasable Bushings
Off Road Design - Sway Bar Correction/Disconnect Kit
Off Road Design - Sway Bar Bushings Kit
Off Road Design - Steering Box Brace Kit
Off Road Design - Weld-in Frame Repair Kit (not-installed)
Front Leaf Springs - Tuff Country 3" EZ ride
Rear Leaf Springs - Stock + 1" add a Leave
BFG AT/KO 33"x10.5" tires on stock 6-lug 15" wheels
DIY4x - UD1 Rear Bumper with Swing out Tire Carrier
Optima Yellow Top Battery D34/78
Interior:
2x PRP Premier High Back Suspension Seats. Drivers side has slider and Lumbar Support. Passenger Seat has Tilt
Stock tilt bench seat
All new front and rear carpeting
LMC Truck replacement Door Panels
Rhino Lined entire interior
Dropped stock 31gal fuel tank, replaced fuel sender, cleaned and primered exterior, all new rubber fuel lines including filler hose
Stock Front GM 10 Bolt 3.73 gears
Stock Rear GM 12 Bolt 3.73 gears
Misc Parts:
NP205 transfer case (had plans to go to a doubler)
GM 14 Bolt (Partially disassembled for planned rebuild, all pieces are present)
4.56 Gear Set for 14-bolt
Weld On Spring Perches for 14-bolt
3/4 ton Dana 44 with 8 lug outers.
These axles were in the process of being rebuilt, but never got around to finishing.
Still have the stock Q-Jet carb if someone was interested in going back to stock. Many people say the stock carb works better than any aftermarket carb.
I apologize that these pictures aren't the greatest. I had to use my cell phone after my digital camera died on me.
http://smile.webshots.com/smiles/21a4431043e90130d6c222000abc820d
http://smile.webshots.com/smiles/2d32a6c043e90130ce2622000abc820d
http://smile.webshots.com/smiles/36a7eac043e90130db2122000abc820d
http://smile.webshots.com/smiles/16a8aac043e901309aae12313f029a84
http://smile.webshots.com/smiles/0d86826043e90130536c12313f0242b2
http://smile.webshots.com/smiles/418750b043e901309aed12313f029a84
http://smile.webshots.com/smiles/f10dd87043e80130dbc922000abc820d
http://smile.webshots.com/smiles/fbae23f043e80130c30822000abc820d
http://smile.webshots.com/smiles/046a735043e90130a09312313f029a84
http://smile.webshots.com/smiles/a2b60f9043e90130dc9c22000abc820d
http://smile.webshots.com/smiles/aac5d5f043e90130d4f322000abc820d
http://smile.webshots.com/smiles/4b5c3eb043e90130d59122000abc820d
http://smile.webshots.com/smiles/558b844043e90130947512313f029a84
http://smile.webshots.com/smiles/714f1ae043e90130a39812313f029a84
http://smile.webshots.com/smiles/68bd63e043e9013046f012313f0242b2
http://smile.webshots.com/smiles/7cc40a4043e90130cb9522000abc820d
http://smile.webshots.com/smiles/8b1c73f043e90130d9a222000abc820d
add 383 Stroker Kit
- Scat 4340 Crank
- Scat H-Beam Rods
- Ross Pistons
Comp Cam 12-249-4
ARP Main Studs
ARP Head Bolts
ARP Oil Pump Stud
ARP Balancer Bolt
ARP Flexplate Bolts
ARP Starter Bolts
Milodon Oil Pan
Drivetrain:
MSD Blaster 2 Coil
MSD Chevy Starter
Dual 2 1/2"Exhaust
Interior:
Misc Parts:
