1980 GMC Jimmy, outside Atlanta
bigjbear
1 ton status
Marietta GA
I don't want to, but I'm in a jam and need some cash. $5000 to be exact, so that is what I want. No, I will not come down any. Nor will I part it out. If I can't get that much for it I'll just keep and put it into storage for now.
So here it is; a 1980 GMC Jimmy with 350/TH350/NP205, Dana 60 front w/ a LockRite, Dana 70 rear open, both have 4.56s. DIY disc on the back. Sky x-over arms & Rockstomper tierods up front. Tom Wood's front drive shaft.
4 12b H1 rims with rubber runflats and 39.5 Super Swampers (2 are new, 2 are almost new), 2 8b H1s with no run flats or tires, also a set of rollers if you want.
6" Tough Country springs, 1' zero rate, and ORD shackles in front. 4" Skyjacker Softrides 1.5" zero rate, & 2" block in back. I'll also throw in a set of 2" TC spring for the back if you want.
Can-Back soft top and a hard top. Cage for the back, made from 2" tube. Rhino-Lined the inside the tub. Pick-up tailgate.
Rear bumper with tail-light protection, rack and M1008 tow points. Front tube bumper from Blazen Off-road, Warn 8274-50 winch with Amsteel blue line.
I will also include Spare D60 shafts, an right side drop NP241 w/ adaptor and spacer to mate to a TH350, Spare rear drive shaft, tube engine crossmember, tube crossmember for a doubler, tube rear shock crossmember, 1" ORD body lift, Ford shock towers, a black hard top with good windows, The drum brakes from the D70 if you want them, 1.5" wheel spacers. Also you can have whatever you want from my parts Blazer.
I haven't started it in a year, the the disc brake brackets need to be welded on (they are tacked in place now), the rear drive shaft still has a 1310 joint, there is no battery. It has rust and trail damage. I'll post some pics when I get a chance. You know you cant buy all these parts used for this price.
