This thread is for the general discussion of the item 1980 Jimmy Build - K5 owner again.... Please add to the discussion here.
Which goal do you plan to start with first?
I would keep the 205 it’s a better transfer case u can get the adapter from off-road designThis thread is for the general discussion of the item 1980 Jimmy Build - K5 owner again.... Please add to the discussion here.
And for the rust por 15 is the best its a one time coat just clean knock of surface rust then apply there metal prep which is acid based then apply por15 with brush and you are done .will never rust again it doesn’t scratch or chip and both can be applied with a brush I bought 1 gallon and did complete frame axels core support and underbodyThat pretty much catches up with where I'm at right now. I did need to make some positive progress so I took a weekend to clean off the surface rust and paint the core support. I'll add some pics of that later.
Next steps for me will be to clean up the frame and apply Rust Bullet converter and some Rustoleum top coat to stop the crust. Then get the tailpan, various patches, and rear cargo floor installed. Where feasible, I plan on using a rust converting product on any corrosion that is mostly surface to save some time. I'm not intending this as a high-end restoration so the main goal is to keep the elements outside the vehicle with all of interior bodywork.
With a little more space in the garage, I spun the Jimmy around as I decided to start tackling the bodywork from the back first. This is where I started to find out how bad the tailpan area was. I have removed all of the rusted sections in that area and found that I will also need to make a patch for the inner wall structure around the gas filler cover. I picked up the tailgate post and taillight reinforcements from LMC and will be using them to patch the minimal amount necessary so I can keep the most factory sheetmetal possible.
The 205 is long since sold. I picked up a 241 out of a 90 Suburban in the junkyard for about half the cost of the adapter from ORD. Honestly, the NP241 will handle things just fine for now. I just want to get the rig back on the road as soon as I feasibly can.I would keep the 205 it’s a better transfer case u can get the adapter from off-road design
