84CUCV
3/4 ton status
i was going to keep this one but now it needs to go. Would sell whole for 3200. have a clean title. all parts in north NJ.. calling would be the best way to reach me. 732 966 6841
Description:
'80 K-20 cut & shortened to 109" wheelbase
350 engine
400 Trans
205 T-case fix yoke
M1008 axles
ORD cross-over steering w/arb studs
ORD HD front upper shackle hanger kit
ORD front shackles
ORD Tuff country 6" front springs
ORD HD rear shackle flip 2
ORD HD rear shackles 4.5 in
ORD Tuff country 4" 56" rear springs
all bushings are greasable & polyeurothane
poly cab mounts & trans mounts
Pro comp brake lines
New, still in box warn hubs
New dynomax headers
2 front drive shafts
1 rear drive shaft
I did weld in 16 ga floors in cab, it would not take much to finish truck. The truck has not left the shop since these parts were put on. There is no bed on the truck, but I do have it, it's missing the hood and one door. I only drove the truck a couple of miles before I took it apart, so all I can say is it did run and it ran pretty good. I'm sure I have missed some stuff, I have over $4500 in parts.
here some pics:
Description:
350 engine
400 Trans
205 T-case fix yoke
M1008 axles
ORD front shackles
New dynomax headers
1 rear drive shaft
here some pics:
i should be use to this by now. axles are pretty much new with 16k on them. lines how is 70 they are new. paid 160 i think for the ord hangers. hows 130
