grnsierra01
Registered Member
I am in Valley Springs, CA and I am looking to sell the whole thing because I don't really have time to part it out. It is basically stock and I have everything to convert it to a manual tranmission. SM465, mechanical bellhousing, pedals, new clutch and flywheel. I also have a 31 gallon poly fuel tank that will go with it. It currently has a TH350 in it that would have to be rebuilt. Each cylinder of the 350 holds about 150 psi of compression and it will run so it should be good to go. The registration is current and on non-op.
There is quite a bit of rust in the fenders and quarters, but if you cut them, then most of that will be gone. There is surface rust on the doors and the passenger side floor has rusted through in a small spot. I am looking to get $1000 for it all.
Edit - Just to add to the deal I will sell all the Blazer stuff and a brand new still in the military crate Dana 60 4.56 gears and all for $2,700. I will not sell the 60 without the Blazer! I will post pics of the 60 tomorrow if I have time.
Thanks!
Thanks!
