1981-1991 Chevy Blazer Full Size Complete Weatherstrip Seal Kit (18 Piece)
1AAuto.com
mass
VISIT US HERE FOR GREAT PRICES 1981-1991 Chevy Blazer Full Size Complete Weatherstrip Seal Kit (18 Piece)
FREE SHIPPING IN THE LOWER 48 STATES
This Full Size Chevy K5 Blazer & GMC Jimmy weather strip kit contains new, aftermarket replacement parts. The parts are built to strict quality control standards and will fit just like original parts.
This 18 Piece weatherstrip kit includes the following pieces:
(1) - Inner Header Seal for Removable Roof
Seals front of roof to body
(1) - Outer Header Seal for Removable Roof
(1) - LH - Bed Side Seal
Seals Side of roof to quarter panel
(1) - RH - Bed Side Seal
(1) - Rear gate glass run channel Weatherstrip Seal
Mounts in Roof and seals rear window when in up position
(1) - Tailgate to Body Seal
Attaches to the sides and bottom of the tailgate and seal the tailgate to the body when closed
(1) - Inner Tailgate Window Sweep
This is the long rubber squeegee that attaches to the inside of the tailgate and sweeps the glass as it goes up an down
(1) - Outer Tailgate Window Sweep
This is the long rubber squeegee that attaches to the outside of the tailgate and sweeps the glass as it goes up an down
(1) - LH - Front Door Window Run Channel Seal
Seals door glass to door when in up position
(1) - RH - Front Door Window Run Channel Seal
(1) - LH - Front Door to Body Seal
Attaches to the pinchweld and seal the door as it closes
(1) - RH - Front Door to Body Seal
(1) - LH - Vent Glass Seal (one piece seal)
Seals vent glass when closed
(1) - RH - Vent Glass Seal (one piece seal)
(1) - LH - Outer Door Window Sweep
Sweeps door glass as it moves up and down
(1) - RH - Outer Door Window Sweep
(1) - LH - Inner Door Window Sweep
(1) - RH - Inner Door Window Sweep
Fits Full Size SUVs with the removable roof
If your weatherstripping is causing leaks allowing damaging rain in, then this weatherstrip kit is for you. Why not replace your old, hardened, rotted seal with this new, ready to install weatherstrip set.
10 Year Warranty
This item is backed by a manufacturer's 10 Year Warranty. In the event this item should fail due to manufacturing defects during intended use, we will replace the part free of charge (excludes shipping charges) for the original purchaser. Please keep your invoice for proof of this warranty.
Hey Tony, this kit seems to be out of stock. Can you tell me when you expect it back in hand? I need one soon!
-Rob
-Rob
We should have them in stock in about a week or two. If you add your email address to the Notify Me button, we'll send you an email when they are back in stock.
Tony
