1981-1991 Chevy Blazer Window Sweep & Run Channel Weatherstrip Kit 6 Piece
1AAuto.com
mass
VISIT US HERE FOR GREAT PRICES 1981-1991 Chevy Blazer Window Sweep & Run Channel Weatherstrip Kit 6 Piece
FREE SHIPPING IN THE LOWER 48 STATES!!!
This GM Truck Door window weatherstrip kit is a high quality reproduction of the original seals. They are made to look function and last like the originals. This is a 6 piece kit to do both front doors.
This kit Contains:
A 4 piece inner and outer window sweep set
A 2 piece window run channel seal set
10 Year Warranty
This item is backed by a manufacturer's 10 Year Warranty. In the event this item should fail due to manufacturing defects during intended use, we will replace the part free of charge (excludes shipping charges) for the original purchaser. Please keep your invoice for proof of this warranty.
This part replaces:
METRO MOULDED PARTS #:
So this is the seal that fits over the pinch weld in the door opening, and the seals for the smokers windows, for both doors? I'm on my phone and can't see the picture quite well enough.
These are the inner and outer window sweeps and the two run channels that the windows roll up into.
If you need a different type for those vent windows, I should have them. You could either reply back or PM me if you would like.
Tony
