19Blaze82
Registered Member
IS there a rebuild kit for the 3 speed. She has a 305 and the tranny is old and could use to be rebuilt. But cant find CRAP on the tranny. Ive used the search but there is a lot of nonsense. with the search results
Sweet thanks for the Replys guys. Its is a Manual. 3 speed with Low. So i guess 4 speed??? But on the Shift knob it says L 1,2,3
Thats the SM465 trans, theres rebuild kits for em out there, but it might be cheaper just to swap in another used trans.
Also the early 68-74 Sm465 knobs didnt say (L) low, the redesigned knob in 75 did, and that continued until 1991. And since your K5 is a 1982, I'll assume it has the orignial (pool ball) style 4spd and Np208 shift knobs still on it.
What`s actually wrong with the trans, shifter slop? A used trans can be bought for like $100 on CL, they don`t usually have major issues.
Well first the clutch is warped so the tranny will be out. But the tranny like when i 4 wheel i will go from reverse to 1 and it will just grind, so i let out the clutch in natural and try it again and it still grinds, there is a ton of play in the shifter
1st gear (granny) isn't synchronized, so it will grind if you don't wait a couple seconds with the clutch in.
How much side to side play is in the shifter?
if it doesn't pop out of second gear it's probably ok, from my experience 465 trannys are noisy and shifters are kinda sloppy for today standards, I have a rebuild kit for a 465 from novak that I'm going to sell if you are interested, once I dig it out I'll list it on here
