Sold 1982 Chevy C30 Cab/Chassis 6.2L diesel
kennyw
@squarebody.chop.shop on IG
Stevens Pass Highway, WA
I am keeping the motor, hydroboost, steering wheel, rear suspension and axle, and doors with mirrors.
Sold:
front fenders
steering column
dash pad
wiper motor
seat belts
Front bumper with turn signals
Complete front suspension
Available:
Grill and headlight bezels with surrounding trim $100
Core support $50
Hood $100
16" dually wheels with roller tires $40 each or $200 for the set
Gauge cluster $50
Gauge bezel $50
Door panels $50/pair
AC assembly SOLD
AC controls $25
Anything else, just ask.
Is the firewall insulation in reasonably shippable shape?
This is the only truck I've seen with those in good shape so far. Only 30K miles on it. The question will be answered when I pull them, we will see if they fall apart.
How are the seats? And what colors are they?
Seats are not factory but somewhat OK condition. I can get pics.
Can you take a look at what the seat brackets look like? Curious if they would work with stock k5 buckets in reg cab
Those are some weird, ugly seats. I still can't tell if they're green or brown. Brown could look cool in my Jimmy, but green would be strange.
I think I'll pass for now
They were tan and brown to start with but everything turns green when exposed to the weather in Washington seats state.
I'm making good progress getting it stripped down. I would be much farther along if I didn't spend for days in a machine shop this week, but it was fun.
The cover for the AC is busted up, the cover on the driver side has extra holes drilled but is otherwise in good shape. The center piece is in good shape. When I get to a point where I can pull them off, I will let you know if they are worth shipping.
This stuff likely will not survive shipping unless I build a plywood box for it. The center piece already has a Crack started down the center and chunks missing around fastener holes.
Yeah they are extremely delicate lately. It sounds like more hassle than it’s worth. Someone more local might want it. It’s pretty good at it’s job. I added it for the noise of the Cummins. Helps a lot.
Hi @kennyw ... Looking for a few parts for my 85 6.2L ... In looking at the pictures above, do you still have from this truck or any of the others you stripped down the Low Coolent Wire wire that goes from the sensor in the radiator to the single spade connection on the left fender by the brake masteer cylinder. Black and Yellow wire.
Also looking for the breather tube that goes from the Resionator to the core support.
The above pictures shows both of these items.
The resonator tube was packed full of a mouse nest on this one. You are welcome to it if you want to try cleaning it out. I will have the wire you want, that could ship in a padded envelope by itself. $5 plus shipping for one or both.
Kenny,
Just to be sure, it is the tube connecting the resionator to the inlet on the core support. Round one end oval other end ... if yes ... I would like it .. and yes I definitely need the wire.
By chance you did not come accross another oil line clip that connects to the radiator shroud that holds the oil lines secure on the drivers side did you ?
Let me know total price and I will send PayPal funds.
Thanks
Rob
Kenny,
Thanks
Rob
I will need your zip code to check shipping.
I read that wrong as I was falling asleep last night as you needed the resinator. I have one extra intake tube, $10 for that. No extra clips for the oil cooler lines yet.
I picked up an 86 K30 with a 6.2L for parts as well if you are anything else you need.
Zip Code ... 77701 Beaumont Texas - Tube and Wire
I need to think about other engine parts ... Do you know if the engine was running ? I may be interested in the Heads and Intake / exhaust manifolds ... do you know if it is the "C" or "V" engine code ? Emissions ....
Thanks,
Rob
Thanks,
Rob
This is a J code, non-emissions engine. I will get the shipping and get back to you.
Good Morning Kenny, By chance do you have a total price on the breather tube and Low Coolant indicator wire ?
77701.
Thanks,
Rob
