camcatmechanic
Registered Member
Originally, I was messing with the back window trying to get it up.. The motor worked fine, but since I left the tailgate up with the window down (worn out rubber molding) for two seasons, well needless to say water got down in there and rusted everything tight. So I tried putting the rear window motor wire in the fuse box marked "Battery" and it worked for a nano second and then stopped working. Then there wasn't any power to the battery port on the box. So I did it again to all the rest of the Battery ports and fried them all. Yet the Engine cranks over, the radio works, all the accessories work except for the ones that relied on the direct battery ports...so there goes the electric fuel pump.
Im not sure if the fuse box is totally fried or what, but where the actual fuses are - those all work. But any port that says Battery doesn't function at all.
I've already removed the 2-5/16" bolts from the fuse box, its still in there. Can't quite remove it from under the hood. Part of it juts out on either side (in the engine compartment) preventing removal in the interior.
I have no idea what to do. Help!
