1982 k30 dually 454
bran6620
Registered Member
Cairo
I posted another thread where I was considering trading a m1008 I have for Humvee tires and rims. I have found through this forum that is a stupid idea lol. Did they stop making humvee tires? I am trying to fit something close to 37s on the truck and want to know a good lift and tire/rim setup that won’t cost 6000 dollars. I’m on a budget but I drive a 454 1 ton. What spacers will I need as well? I’ve never lifted and put big tires on a dually. I know the lift will be same as a normal truck.
Are those 235 85 r 16 on there now ? those are just under 32" . For 37's you need 2.5" clearance. So 2" TC ez rides an easy inch to move the axle if needed and 2.5" or 3" block.
some good shocks and may be sway bar correction. Stock steering linkage should work.
