T
TankerCadaver
Guest
Hey all,
I picked up this '83 Blazer w/ a 6.2L about a year ago ($1200) and I've been slowly going through different systems, etc. getting everything up to speed. I've replaced the glow plugs, GP controller and relay, etc. I've cleaned up a bunch of wacky wiring the previous owner had in there for stereos/amps and stuff. I've replaced the batteries and did the brakes. I'm just getting ready to go through the front end (tie rod ends, ball joints, hubs, etc.). It's frame is good as is the tranny and axles. The body is fair with some rust here and there. The top is good and all the systems work fine. All and all a pretty good buy in my book at the time.
However, disaster struck this morning.
I was accelerating onto a highway and after I lifted the accelerator I could hear a distinct "clacking" sound that wasn't there before. The engine still has plenty of power but this sound (which keeps rhythm w/ engine speed) is definitely NOT just the diesel engine clacking sound. This is more akin to a small block that has a bad lifter/rocker, bad valve or a wrist pin that's about to go.
Logic tells me with the compression ratios these things have it won't be long before this engine goes in a bad way
Are my assumptions correct?
If you were my shoes would you:
Get a used motor and swap it out?
Get a rebuilt motor and swap it out?
Rebuild this motor?
Sell the whole pile and look for another "fixer"?
Not having a lot of experience with the 6.2L I'm not sure what I'm looking at as far as cost, labor, etc. I've swapped out engines and rebuilt small blocks but I don't know what to expect with a big/heavy block like this.
Thanks for any help/advice you can provide!
Rebuild this motor?
