1984 K30 M1008 Cucv build
Cucv_M1008
Cthulhu Forever
Pendleton, Oregon
So here is my rig. It was a stock M1008 for a while It has now :
2WD steering box taped for hydro assist steering.
Custom PSC hydro assist lines.
Bolt in cage.
Np241
AGR rock ram with custom brackets .
Custom front drive shaft.
Industrial Off Road Dana 60 cover.
WFO spring plates,shackles,u bolts and Dana 60 steering knuckle studs and pit-man arm,cross over steering arm and tie rod custom cut to length and tig welded ball joint ends.
ORD k30 shackle flip in the rear,front and rear zero rate blocks
Rear leafs are the stock ones with the top 5 springs and over load and a zero rate.
Front springs are 4 inch with a zero rate.
XRP front and rear brake lines
BDS shocks for a 8 inch lift.
used rims and tires for free
Fixed
you are a member and have enough posts
you should be able to upload either from a photo sharing website or straight from your computer :)
sounds like a nice truck!
I really wish I had the cash to find one of these to build up. After tearing one apart for the drivetrain it seems like it would have been more fun just to keep the CUCV and wheel it. I really like this one. Looking good.
I like it a lot! This is what I wish I could've started with. I love the CUCV's
they are 37 pj's but i have a set of 37 military good years i am going to put on with diff rims. Plans for now are just to go through the 60 and rebuild it and install a free track lock I got for it and rear disk brakes on the 14ff. As for long term plans just a nice camping occasional wheeling rig but Im leaning towards making it a expedition rig and not so much a hard core wheeler
I can do 70 and its really not a problem but I don't feel comfortable going faster than 70.
That's the same lift I'm doing on my k30 right now. What brand front springs are you running? Awesome truck :waytogo:
I need to pull my intake and fix my fuel leak ,diesel is,everywhere yay....and it needs front brakes, there are two diff brake pads for dana 60's? I installed some truck light 24v lights man are they awesome!
I got tired of the hood being rusty and paint peeling so i started to clean it up today. Tomorrow ill tape it all off and sand it and re primer and then paint the center flat black and the side of the hood tan :thumb:
I had to pull my intake last weekend, took about an hour. Be sure to look at the rubber inlet to the pump.
I think there is only one style of front pads.
I have no idea where the fuel leak is coming from i pulled the intake fixed stuff still leaks I think the pump is bad, so i said F it and i am buying a tbi 454.
