I just had one of my belts break while driving and after closer inspection all the belts should be replaced (it's a new purchase and the belts looked fine but were not). There is no belt diagram to be found, but the broken belt did connect the water pump. I do not know if it is a 305 or 350 either. Both my mechanic and I looked for quite some time for any identifying numbers or marks.
The K5 does not have AC. While I can sketch out the remaining two belts, the one that broke remains somewhat of a mystery although I can retrace the likely path by wear patterns. I would still feel more comfortable if I had a diagram in hand. The broken belt is Carquest Part No:
If anyone has belt diagrams for an '84 305 and/or 350 it would be very helpful.
