Good Afternoon Gentlemen. Moved this over from the wrong section. Been a premium member for almost a year, but have just been silently using the boards to learn and move forward on my project. Have gotten to a point where some advice would be welcomed. I bought my 84 last fall as something to keep me busy and boy have I been busy. Truck was originally from California and made its way to the Northeast in the last 3-4 years. It has some old battle wounds on the roof, which I could tell were deteriorating underneath a healthy layer of filler. I started to peel back the onion, for better or worse, and have revealed the extent of the rust. Its about what I expected. Finding donor sheet metal worthy of working with has been a challenge up here due to the typical rust of the Northeast. With that said, I have found a few donor sections to work with. I cannot find the passenger side door drip rail/door frame/roof section from a blazer which is where I'm looking for some knowledge/advice. The donors for me were from a late 70s early 80s (from what I can tell) roof section from a single cab pickup and a roof/windshield frame/pillar section from an 87 suburban. Has anyone here repaired this section of a blazer roof? From what I can tell the windshield frame, pillars, and center roof section are all interchangeable, but where the roof blends into the drip rail over the door is my concern. Has anyone tweaked a standard roof without factory rails into a blazer with factory drip rail section? Here are some pictures for reference. Thanks in advance. Eric
Enjoying following along
