Your alternator & battery were probably still good--it's likely the alternator isn't getting the "signal" to turn on and start charging..
On an '85 the alternator has 3 wires--one connects to a stud on the back of it (thick red wire),and the other two are in a plug that plugs in on the side of the case towards the back of it--both those wires in the plug must get 12 volts when the engine is running in order to activate the alternator and provide the right amount of charge..
If you know how to use a test lamp,its easy to check to see if all the wires are getting the proper voltage--the test lamp has two wires,one goes to the negative battery terminal,the other end (usually looks like an ice pick) is touched to the wire or terminal you want to check for voltage..you could use a volt meter or multi-tester too,I prefer a bulb,because these wires need to deliver some amperage,and sometimes a meter will read "good",but in fact the connection or wire is not able to deliver the full amount of amps to operate the alternator--it takes a bit more "oomph" to light a bulb up,vs make a multi-meter read voltage..
With it running,test for 12V at each wire on the plug on the alternator...my guess is you'll find the thin red wire has power,but the other wire,usually a tan or white one,wont--and that is the wire that tells the alternator to charge..that wire has to get 12V with the ignition in the run position..
-one quick way to test for this is to use a jumper wire to connect both of the wires on the plug for a few seconds,then remove it--you will hear the engine slow down a bit and the alternator whine some,when it starts charging,if it wasn't charging due to lack of voltage at the tan or white wire...(It may continue to charge after you "activate" it,until you shut off the engine--next time you start it,it is likely to not charge again..
if no voltage is present,you'll have to trace that wire tan or white wire back to where it enters the firewall on the back side of the fuse box (next to the steering colum)...if it has power there ,with the key "on",engine not running,,then somewhere between that junction and the alternator plug ,the wire has failed somewhere between the fuse box and alternator..and its easier to just run a new wire from there,snip off the old wire,than rip apart the harness..
The thick red wire on the rear of the alternator has 12V all the time,even with the key off--that wire should light up the test lamp if all is OK with its circut...if not,you'll have to trace the wire back to where it goes to the harness behind the engine--there it a "T" splice in the harness for that wire--one side goes to the starter solenoid where the positive battery cable goes--that wire has a fuse link ,that is where it gets power from the battery--if the fuse link burnt out or the wire gets fried from a short,they will need to be replaced..
The other side of the "T" runs behind the engine and ends up at a junction block near the brake booster ,that is where the cab and rest of the truck gets most of its power from...
I don't know if your able to do these tests yourself,but its pretty easy if you have even limited electrical skills...
