PRICE REDUCED!! $1500 Testing the waters here before I dis-assemble and scrap. First and foremost, it will need trans work! The original TH400 is slipping. I have no idea what the problem is, it moves well enough to drive on and off a car trailer but I would not try and drive for extended distance!! This is actually a very solid 3/4 ton Suburban. Same owner for last 20 years with piles of maintenance documentation. 127,121 original miles with only 52k on GM crate engine--have docs to verify. It has the semi-flosting 9.5" ring geat rear end. It is a Silverado edition, so it has A/C, cruise, tilt, PW, PDL, rear A/C, has working factory clock in I/C! I have not verified that every electronic function works properly! Engine runs excellent-super smooth and has an Edelbrock carb on it. Has 2 sets of wheels and tires, studded radials on it now and a set of pretty wore out tires on aluminum rims in the back. It has had 1 repaint, and the docs for that are included. Tiny bits of surface rust, but nothing major. Worst spot is on LH rear qtr behind wheel opening, you will see in pics. Has tailgate instead of barn doors and a factory rear air deflector. There is a dent in hood, and it will show up in pics. Dash is uncut, and interior is actually really good except that the drivers seat is broken down a little and the dash has typical cracks. And as is very common, the headliner is coming down!. $1750 is what I need to get for it!!
