Let's go to Blazer Bash!!
I've been on a road trip to Colorado in my '04 Tahoe for almost two weeks (2800 miles!!) with no issues besides a headlight fire...LOL, buts that's a different story. Got home the middle of last week, had to work, so I only had this weekend to get the M1009 prepped for Moab.
I started with the prerequisite nut and bolt check, and found a few loose bolts here and there, like the lower front shock bolts and the rearmost steering box bolts. While I was under there, I saw some coolant dripping down around the starter. Further investigation revealed that the passenger side rear coolant crossover port block off plate was leaking. I had some spare gaskets already, so I got to work on that. Had to pull the vacuum pump to get to the plate. Cleaned it all up and reassembled. The plate wasn't in the greatest of shape, with some etching and kinda warped, so I flattened it the best I could and flipped it over. I will have to keep an eye on it, but in the meantime I ordered up some thicker replacement plates from Leroy diesel.
Then I saw some weeping from the fuel filter base. Great... I swapped box filters, hoping it was one of the gaskets on the box, but the leak came back. I knew this was going to happen at some point, as the bases are notorious for leaking, but the timing was indeed poor. I would of liked to pull the base to replace all the O-rings, (I'm thinking it's the water-in-fuel sensor O-ring) but there is no kit handily available. So, I bypassed the box, installed a three way shut off valve, and a 10 Micron inline filter from Evil Energy. The filter is cool because you can use different fittings on each end, so I have 3/8" on the inlet side and 5/16" on the outlet side, to match the factory hose setup. I'm not very proud of this setup, but it allowed for easy priming and will get me by for Blazer Bash.
View attachment 511798View attachment 511799View attachment 511800
When I get back, I will upgrade to a spin on type filter and housing. Unfortunately, the AC Delco G Van housing from the late 90's is out of production, so I may go with the Stanadyne FM100 or the unit off of a Duramax.
Now to go get this thing on the trailer!!
