Didn't get much done last weekend, as I helped a buddy work on the fuel pump in his '94 Suburban. Turns out the "shop" that worked on it last spliced the in-tank pigtail with butt connectors, which failed.
Back on in a bit yesterday, the process has taken an incredible amount of time to get everything cut and fit just right. I actually started with the outer rocker first, then cut the floor pan patches to make sure everything fit and was happy. Nothing is welded in just yet.
Foot well patch is dialed, also drilled some holes to plug weld it to the floor support:
When I was done and cleaning up yesterday, I sprayed a bunch of Seymour rust converted into the hidden areas. I plan on spraying Seymour self etching weld through primer on all the bare metal edges to be welded. Also, I picked up a new welding machine, a Titanium MIG 170, and have been messing with the setting and such to get my sheet metal welding just right.
