TX 1985 GMC Jimmy K5 LS swap project for sale - Removed, NLFS
rpcraft
Dallas
GlNPPlxIhG5cPl4t-uTt1JNiM2rQKGp-WB2_jf1SU1zq2fyz7bZcXQHAdR0yWV1r95w0q227IEf98lTs40lyXn1fyJVb3CIQEbM8eKCBKcAK957eg-ARTRpbH61PgQjrjFnzrBRwp-JZ0PHTinqbZIRpysyRXlU9xeZ0uTBsLY6UXk9XU9fWuYju5O8QUz6hoEnbiVP12Cl5HKoRNoU-GoM4XYU4yXUbzoP8wK7_EhdbNkqHy_H38sZvK2DR3XJT7lIMODonzsJiwrzTrgJGeMHTrrr5aufiYsHPcjS-SXXJQVml0qISdG44Sk6YxFSZMWLDY3EIx7J2BlsYuN9dFCw60sAWvFF2rnWO3j3B6_ZNFGucd07W6z0mxj8ufCtXejentbVcsCo6NE0Vee-6FvdTcoELYR5TNb4JTQJXoQ-tg8bcDaohNL0QKM8S_arNtF6SZjvXMGi52AynBv80frj7JAdxsxlI_eMvfGf0Up8DqPYd20740YwXtBzL_uCJ_60VYrO3MCoo8Z4VvjtZRZjgEOyjZF5WzPq2dpRpfWbKrnGnh4i9rRikNOCAg3s9e4Hes_WrAxoXe5hTBDfp425FPVEpdPMp1kE7rsA3JuGHH2-1FzMCiHW_OTPgHVF8bkVhfJT6WZJK43vozjxpLJ9MCp5T9a7mwMNPkZ78m2Q=w1371-h1028-no
1985 GMC JImmy Sierra Classic - Interior is rough, minor rust on passenger floor board (doesn't need whole pan replacement, just spots patched) some rust also below the seat belt mounts pillars. Can be patched in with raw metal, no patch panels needed. Top is missing some bolts, thanks to the previous owner. Carpets will need to be replaced. The springs are in great shape. Early photos have it looking like it was squatting some but one of the tires was blown out and at that point it also had the transmission and all the hardware for the engine compartment in the back of it. Also not with the truck are a back seat and center console, but I was planning on going with a late model Tahoe rear seat(as well as some 2003 era front seats too). I still have the original buckets for the front. They could survive with just a cheap set of seat covers but your mileage may vary.
Motor - 2000 GMC LM7 (iron block with aluminum heads )that had less than 75K on it and was running (included a 90 day warranty on it when purchased)
Harness and PCM - Came from the donor with this motor (unmodified at this point)
Trans - 1997 4l60E with older 4 bolt rear adapter mount & 125K miles on it, was pulled running with no issues (not rebuilt) - compatible with 2000 PCM
Transfer case - NP208 (original setup)
Axle ratio's are stock 3.08
Tires are 33 x 12.50/R15 (three are worn Goodyear duratrac's, good for rolling around. One tire is a brand new General Grabber that had to be purchased to be able to roll the truck around.
I have many of the parts needed to do this project but just lack the time. I travel a lot with work more so than when I purchased the truck and motor. I thought I would be finished sooner but life sometimes changes things suddenly so with the amount of travel i have no time to work on it.
Right now the PCM and Harness have not been setup, but I have them boxed and ready to send out... For the 4200 I will send it and have it done for you with a reputable supplier but if you want to negotiate downwards and not have it done I am open to suggestion.
This deal includes the front fenders and front hood (which has a crack down the middle, which I have not seen happen this way before) as well as all the parts on the front end and a new 21 Circuit EZ Wiring Harness (well marked and labeled on each wire) to re-wire the truck (not installed). Also included are a a new TBI baffled 30 gallon fuel tank, OEM LS in tank pump, sending unit, water pump, fuel lines (Dorman OEM style nylon lines) corvette return style Wix filter, Russel fuel line adapters to cap off the LS intake return as well as adapt the Dorman line to the fuel rails, LS Flexplate adapter (both styles), Speed engineering LS swap headers, LSX engineering block of plates for the intake, original AC/heater box and parts, aftermarket cold air style intake setup (as well as OEM airbox with MAF) original HD Radiator made of brass an upper radiator hose, some tune up parts (new plugs wires, knock sensors and a plethora of top end gaskets). I have a extended snout to swap for the mechanical fan and place it in the shroud properly but obviously if you buy this project you can go electric fan if you wish but I had not set up the parts to go that route.
I have installed the motor on Dirty Dingo mounts but just have not had time to finish mounting the transmission and transfer case, with an extra pair of hands it could probably be done in a few hours and I will probably continue to tinker with things that do not cost me money to make it more complete. If I get it to the point where it is running I am still probably going to sell it but I figure that will make it easier to sell as well. The truck is missing a front driveshaft and the front inner fenders, not to mention some fool at the previous storage yard broke a hole in the windshield. I took the inner fenders out for swapping in the motor and cleaning the front end up but they were fairly rusty where they connect to the front core support so I was going to get replacements.
Obviously this is a project, so its what you see is what you get, and I also have a list of parts that I have not included simply because I decided to list this in the past 24 hours and I just have not had a chance to make a complete list. I am negotiable on the price of the project and would prefer to sell it outright so as to clean out my spare garage all in one shot (and stop it from costing me monthly storage elsewhere). I am not being pressured to sell so while I am willing to negotiate I also have a limit I will not go beyond and willing to walk away if the deal is not right for me (or both parties). All appreciable offers will be considered, and I'm open to some trade items as well, such as motorcycles, quads, and some personal watercraft, so long as they are not total wrecks. I'm going to include a few pictures but link the majority of them as a link to my shared google photo album. Thanks for consideration and this weekend I will probably go through the parts I have and make a more detailed accounting and follow up properly.
LZfEelMCN_he5bcotFW3gboO43zzwvZ0wNbHbf3vYxczM3vp6Mndg6yXx5DtUjvqNVRIdcn4Ckf5hyAIlt4uCH1IShvSeaoGziw9mw2JB3qY8_q5WiEVaaXyp_W21ULmJ4rE_NwBr93nqN3Qqm8vN1tuF76j1zitYUjCVlf3AzL-WJi8Uq1TqMBV0fL_5aSqVaLFoka6PJQMi0AaaQ2nchkIUcKshQZnmQ-dlq7aQiRjFmK0XR8bb9EWAD-mf7wF8NxQjY6LFkEGxJNak5HmtBky-e92B-Z3_UAQ9TRMdYL497I0BA8zn1t-fSQeAC4r7hcO7iVGl0w5AQubwx-c_Tc1VtYyEiUJ5JNVlJi90KdhR-tdVIZr3WR64ZMQtYJyKNv-Iub9Ml3RBlfGBJbVEubyFqGD_gTrWeju-qYsrOxTKBSoyRvGRHn6gcuaYykqOop6-S_Ofjtk6op4VpyUaI5kOP2M0FYrT22GOnDgolV4Ix4aaweSt62FM2KLp5lw2uG42TvoQnrGPVfnEVRhdR79R1IT107Pemht6wcrKdX50xFo-z58Ucl49jNci9NOAqt-6wccezZChqMEB1E46DL4daHqwDbxXGoul1W21KgD4ndEQH1QmeFWdxCphYZXu5_xhA18k3pfY02I1JDgO2obkxvGYNtMNfr3Vws4EYw=w1371-h1028-no
qrs4h7PmtVh16CEgnzPUyqB95AY_ttnhy6LzWtuI6Cy-AF1poqSxQUsm0WsXb9Tv08K67VqnMVMO0b7vze85IcFXPg8gOcE5csfvqNzJmNNGHkiZR2Ux-MfC8js8oTWb92LSd1Y6105bROFOboUk-v1bXd4xLZyByfPltVedr49GEBkv8gT7Un0zGwxkJbgeffxsQAAL2eU6vz0_KJSGWVfDdKLvNO0T3ZizgR5kZXs70OpqOBmJGv30q1ZvGfgdfMGgxIUhZBJrW3fujjUGR0IKoHiY733H5izImeywjBa7KK1WwCxRN-2odW8uNF5NBOmidzDwh1EGM6FwnOK074bn7UVWHA6jhpd7OMV9bshy-ctQnEtmcZP9c8gtQd-HizDXXSfIHVROKFa-pq09MMJath0T7cWOEt77ds97PYapjTYEEbIxMCnNKZgr6GJLs263S8qL5qPQ4dfRuyuJ0YvuS0k3pHnsdS8RfxzsXpxnpXkVrUis25Qtm8VK2btC7ebPdwtfhW0OQmaMjF2kNrk8l4xa-uzGAI_DqDqOUJK-PQams2GMle_PvYiEOY-fWYcV7Hxlect6icryxaVfephTze9ddE7rZj1pZi3YCt_3SAScVe8x0T1UsOmNak5mxgbYVDqDlh095zuSeiSy6Ow4P9fTaRxGMUdZDzkydpg=w477-h358-no
A6ZuYPuVX9KHg-RbWzUHedM79AYatQvpvHUjB0zRK0WjyIjWoasn4CFBHPOxgcYQljxE03OMzOnxg9JyRawadsRMkGmZsQwk7w41ftd_dm8TnohgoI79GghPXQh8lElI4_1evMOi1xwoAW5Ah9cSzeGxplb1fo24vx9B2MRD0zhh3v0Kw5OOUaPhWHTSvkxzGwVekJpImjd3EMAYMd_0T3v1f6NKwphjHyNUz1Ur9buJEIxwGDuZsSstpQx9mJrj0gsfrQFyaf7MFZdFvb3fiaRK0908u5VtnzsuqsNdO1E87BPOXSEYIFI47UB0gYG7UBj31jRDmE408UI5XA3jGouc5nfdtFBh6DQU_8QIarkDARbC0aEdl9Ev004QCcm5NDQW1ewPE50gawVFlgFXUNdLv4YxsWrbrqPmVsq4qtn3YhuO-ZKYTAe-vBWMUMU9kcqCqq8NUmiputdvI5RUnMKkjreYJpFiLqUYwx3RUmDoEB5kxOBYrbVtu_J0W4DbY3ebbjEu2QMtFHh5tWO3xQRybOwErdWmJ6IOldnCro_ln47bEOiSqMLTAp66ZfanOUlgg1NhnAbFCUuf5EJlkDvIdPO8u4uYMRv1_sg4GPowJd6Xs9RPWLgQkRQjlZ2JXT_pViMV_PNlFM12Pf5mqHkh_UHFLCTBOkGuMNXwq6s=w1371-h1028-no
vUomeCEmK6Twf-3neSazL2anoXMDh09GYw9Dd-FWPozN4v6ZU0tMWJOoAxVDLuClsD2x62PfGoi8oRDMHB2p1PZxjtrbM0txg6xXOCMgEiXs4rfv3KpgKg-NSeujgB1-JRSieR7oRMbJoUX6ooOJuGbGGIpN0xeUaFPZRmzzqusvZH3TntxqCNSnVk_3zfDogZetBxzln8S2iGZUzGYUDJY5Mjoo0MQdnDWx8u_PQHqOtqmdBzTs8CmzMNUbRO0DpuoWLBLDVVjdv9UPUuvSlr_wloR4YBVJkXhiA0M3fWRve65odnT1dK7A3bVGKx0__DOdA9RRGqtUdCTZ-EmvsAyiL-5rIcRsvbQJ3psdzVYE9J_Wq6Ifhy_uWPljm_vfbWJFtmjvcLwV4fqZkv7BH0xX1qG_hplvBW21iCOS0-mYk4kWDo3sPAej28OOPR-7qbrufYGVvK97YAo38yYXZY7k2oucWlcKkNjHy23Z3GVTYcAieSaXBWm44AMPPg6FA6k0V9ZcC-rufCRZf7UElMOk_kjYXPwBuS3xKnLEF9XYWhabMURajZGDTxKNMedMw97PgQks1xwBxN_WoOLRli3wRpcx7jZDBB6AHQYNcrptLevs6yZ4FTrNv6ukabojZb77Ycw5KtUATWXDro5vKvSwy7rJbchaJ6xc0YBdvko=w1371-h1028-no
Google Album: https://photos.google.com/share/AF1...?key=VFFmX29tdGFEcGZmTzJrV1FuNmFtaHgxOE1JRlBR
