H
Hop-up
Guest
This is a 1985 Chevrolet silverado.
It's a half ton, single cab. It is a 4x4 truck. It has an 6" suspension lift with 36" Military Grip Spur tires. They are almost brand new and have great tread. It has 3.73 gears.
Originally it had a 305 SBC with an SM465 4 Speed ( Granny Low) transmission.
It now has the original SM465 with granny low, but with a BRAND NEW CRATE 350 SBC.
The motor is a brand new crate motor from O'Reilly Auto Parts. It has 1600 miles on it, almost exactly. It was broken in with Hi-Quality Valvoline 10w-30 Oil since it was new.
The motor was installed three weeks ago and most peripherals were replaced. Here is the list:
*New motor mounts
*New Water Pump
*New Oil Pump
*New Summit Performer-style intake manifold
* New OFF-ROAD built Quadrajet ( over $300 )
*New Pilot bushing
*New Air Filter
*New Thermostat
*New Radiator hoses
*New Battery
*New Starter and cables
*NEW CLUTCH and MACHINED FLYWHEEL
*New Clutch Master Cylinder
*New Transmission fluid
*4 New Superlift shocks
NEW EXHAUST
*Summit long tube headers , need to be repainted but comes with paint.
*New pipes run. true duals with summit glasspacks. Dumped behind cab. All exhaust painted black to prevent rust...and look good, too.
I'm sure there are more items, I just cant think of them.
There are a few parts that will come with the truck to be installed:
*New Black Steel Valve Covers, Black epoxy painted with two breathers
*New Black steel SBC oil pan and gasket
*New emergency brake cables
*rear superlift shocks
*New Passenger side rear Wheel cylinder (drivers side rear already replaced)
*Ramsey 8000REP Winch with wiring. Wiring is a bit old and will work but should be re-done. (Truck has a stubby winch bumper on the front. )
Here is what needs to be repaired on the truck. You could drive it as-is and fix while you drive.
*Front axle - The pinion yoke came off, the PO didn't put a pinion nut on. The yoke will need to be re-installed. The front drivehsaft could be lengthened to compensate for the lift, if you wanted.
*Needs rear brake pads
*Needs both exterior door locks replaced, I do not have a key for them
*Needs window tracks for driver's glass.. window rolls up and down fine but rattles when it's down.
This is a great, strong truck. It has many, MANY new parts as you can tell. It needs little work to be a great truck - Daily driver, off-road toy, or project truck.
It has a Texas inspection sticker and temporary registration in my name. I do NOT have a title. I do have a bill of sale from the P.O. in georgia. Feel free to pay him a visit and get the registration slip which is what you need to get it registered.
Im asking $2500 cash firm. , it needs to go fast. Like really fast.
Located in Jackson, Tn
281-455-7015.
*New motor mounts
*New Water Pump
*New Oil Pump
*New Pilot bushing
*New Air Filter
*New Thermostat
*New Radiator hoses
*New Battery
NEW EXHAUST
281-455-7015.
