1985 K10 Blazer...
k. williamson
Newbie
Houston TX
I just picked up this Blazer. I thought they were all K5's but I guess i was mistaken. The badge says 10 Custom Deluxe. When I look for parts though everything is either for K5 Blazers or K10 pickups. Are they the same as far as parts go?
Sounds like someone may have used a fender from a truck. Trucks were 10's, blazers were always k-5's. Regardless of 2wd or 4wd, blazers were always k-5.
BTW welcome to the board!
Mine just says blazer. I was wondering what t case I had too. I do know it has a 700r4 trans cause I just replaced it. From what I've read I think it's a np208. It has a rubbing noise coming from the rear shaft.
It should be a 208 if it has not been changed.
And yes, most of the part from a K5 and K10 are the same. Some are for the Blazer only, but most will interchange.
