New gas tank and brackets, new radiator, replaced most all of the brake lines. Some minor rust holes started on bottom of box sides. Installed a 350 with low miles. New exhuast. 700R4 transmission, 208 transfercase. Replaced inner front fenders with used rust free. Replaced doors that are rust free, but have some dents. I pulled the carpet out expecting to do rust repair, but found it completely solid. Except the drivers outer rocker that I replaced.
4inch lift (rear blocks). Heavy Springs
Has 100,900 miles. Engine maybe only 20,000. Can not say for sure on engine.
Tires have about 1 months use on them. A/C not hooked up, heater works good, lights all work.
1985 K10 Silverado. $3200. I have a Car Fax.
I had it for about ten years, used for plowing only my drive.
$3600. truck with plow
$600. only plow
$3200 truck no plow
$600. only plow
$3200 truck no plow
