I am working on changing the intake and carb on my K10. I have a couple of questions;
1. My thermostat housing has a sensor which I assume is the temp switch and another nipple with all kind of smog vaccume lines. The temp switch has a wire that runs from it to some sensor in the carb and then back into the harness. What is this wire that runs to the carb and is it needed?
2. On the drivers side block next to the exhaust port there is a sensor with one wire. Is this the knock sensor and can I leave it dissconected since I am getting rid of all smog stuff?
