*1986 Chevy K5 on 6"+1" lift
*Very clean truck, little to no rust on the body at all
*1991 Chevy 350, with 5000mi on professional rebuild
-runs strong
-includes EFI system which was pulled from the '91 complete with VSS.
*Th400/203/305
*1410 Yokes and new driveshafts with .250 wall 3" tube with Spicer ujoints
*Dually Dana 60/70, the 70 is welded. 4.10s.
*Rancho 5012s on all 4 corners, fronts have Ford towers.
*Hummer rims running 36" Goodyear Wrangler RT-II's
*WTO hydro assist (1.75" ram)
*ORD box brace
*Rockstomper crossover steering
*8 point cage, runs thru the dash and hugs the ceiling.
*OBA! York 210 mounted, but still needs install (I've got most the parts already on hand)
*radiator.com 4 core rad.
*mechanical fan & ford electric fan with elec. thermostat sw.
*Large tranny cooler
*ORD: front shackles, 1" body lift and poly body mounts.
*Newer 3" exhaust thru a single factory catalytic (probably could pass emissions, although I've never tried!)
*stainless brake lines
*Borrego rear flips with heavy 6" shackles using 57" ford springs... which need to be replaced.
*Toybox offroad sliders
things wrong with it:
*tranny needs R&R
*rear springs need to be replaced
*1410 yoke on Dana 70 is broke
*Hydro cylinder leaks at the seal, WTO will rebuild it
3500.00 FIRM
42's are on my cherokee; bumpers are going on my street blazer. i have dropped the price to reflect this. i think at 3500 it is still a good deal. the parts are worth more.
-runs strong
*Th400/203/305
*ORD box brace
*tranny needs R&R
3500.00 FIRM
