1986 C&C Tow Capacity?
hmatiak
Savannah, GA
Truck in sig. Looking at my next trailer and wanted to know if anyone had some hard specs like GVWR or the max rear axle weight. 4.10's BTW. Thanks.
GVWR could be as high as 10.5 or 11k, though it depends on the particular spring packs and brakes on your particular truck:
http://brochures.slosh.com/1986/ctfb036.jpg
The 14BFF is alleged to be good to 7500#:
http://brochures.slosh.com/1977chevy/pickups14.jpg
You should prolly run your VIN, as IIRC it can get you at least a range for GVWR...
http://brochures.slosh.com/vindecoder.html
Have I pimped myself enough yet? :haha:
-- A
Thanks much sir. Ill check out these links.
This is all i got.
Country: USA
Model year: 1986
Made by: General Motors - incomplete vehicle
Drive: 2WD
Engine: 454 V8
Series: 1 ton (30/35)
Body: Pickup
Plant: St Louis
Serial #: 127148
