I recently purchased a 1986 Jimmy 5.7 w/ SM465 in nearly original condition w/ all factory SMOG system 100% in intact and original CCC Q-Jet, air cleaner, cold air hose etc.. I am having fuel issues @ carb as it will not start w/o manual priming. I am worries that well plugs are leaking however i plan to make pulling carb a last resort as it runs perfectly after finally starting! After getting running this weekend the fuel pump began to leak from weeps therefore i plan to replace. While trouble shooting I began checking wiring and found that sensor in t-stat housing w/ wire going to carb had broken spade, see embedded image. In order to replace fuel pump i have to remove smog pump for access purposes. That being said i would like to go ahead and remove all SMOG equipment from the truck and plug ports in manifolds. I have 3 questions.
- What is the GM part number and or proper description of this sensor?
- Will my CCC Q-Jet run properly after de-smogging? If not, what needs to be done to run correctly
- Does anyone have any suggestions for de-smogging and or references to previous threads for how to? I do not want to cut the wrong stuff out or remove vacuum lines that I may need...
