josh86k10
1986 Chevrolet K10 SWB Silverado
Engine:
305 V8 4 bbl Quadrajet (emissions equip removed)
Dual Flowmaster exhaust
Accel Supercoil
Trans: TH400 (~6000 miles since rebuild/swap in place of the 700R4)
Replaced Dash bezel to match shift pattern
B&M kickdown switch
TCase: 32 Spline NP208
Axles:
Front: GM Dana 60 (from CUCV)/4.56/Lock-Right/Warn hubs/Spicer joints
Rear: GM Corp 14bff/4.56/Lock-Right (Drums complete, e-brake functional)
Suspension: Overall ~7" lift
Front:
6" Rough Country springs
ORD Zero-Rate (axle 1.5" forward)
Rear Shackle hanger moved forward with longer shackle for better shackle angle
Rear:
ORD Shackle-Flip
Skyjacker long add-a-leaf
ORD Zero-Rate (axle 1.5" back)
Steering:
ORD Cross-Over (Low-Steer)
Heavy duty solid tie-rod
West Texas Offroad "Redneck Ram" Hydraulic Assist
ORD Bolt-on steering box brace
Weld-on steering box brace (frame was/is intact at installation)
Wheels/Tires:
Trail:
39.5x15x16.5 TSL's on Recentered 12-bolt H1's (pressed centers and PVC inserts from USA 6x6)
Street:
37x12.50x16.5 Goodyear MT's (HMMWV radials) on 16.5x9.75 Aluminum Westerns (look like AR Outlaw II's)
Other Stuff:
Custom bumpers front and rear
Long-travel front driveshaft (21" slip, ready for 52's)
Rear shaft is also new to accomodate lift (still slip yoke style)
Bed Mounted Aluminum tool box
Ramsey Patriot 9500 Winch
2000 Silverado buckets with integrated belts
Custom seat mount/interior roll bar (ties into b-pillar at factory seat belt mounts)
Tuffy 10" lockable console with cupholders and CB radio slot
Aux reverse lights and rock light
LMC Truck MIP floor mat (now installed)
Bushwacker Cut-Out Flares
Stock replacement radiator (3-row I believe)
This is a very nice truck, and it is with a heavy heart that I have decided to part with her. I simply don't get to wheel her as much as I'd like.
It started out as a very clean stocker which was my daily driver for years and is still in very good condition. All of the gauges and switches work, there aren't any cracks in the dash pad. This truck had factory A/C and the parts are still there; however, there is a leak somewhere and it has not been converted to r134a. The only rust to speak of is in the cab corners (see pics). In the interest of full disclosure, there are a couple of body filler cracks (see pics) and the paint is starting to fade on the roof. It does see the trail so there are some scratches. That said, it is a very nice truck as can be seen in the pictures. She drives great on the road, especially with the street tires. I just ran 75 mph on interstate for 3.5 hrs to get her back home from my dad's place. No problems at all.
Asking $7500
Engine:
Accel Supercoil
B&M kickdown switch
Axles:
Front:
Rear:
ORD Shackle-Flip
Steering:
Wheels/Tires:
Trail:
Street:
Other Stuff:
Asking $7500
. It is Rustoleum after all (and almost matches the center stripe no less).
