MD 1986 K5 Blazer – Rust-Free Full Convertible Conversion Build (Project)
bigrik71
Newbie
Frederick, MD
Figured I’d post this up here for the K5 crowd. This is a solid ’86 Blazer project that’s had a lot of the heavy lifting already done. If you’ve been looking for a clean squarebody to finish your way without dealing with rust or major drivetrain work, this might be worth a look.
Key Details:
  • Rust-free body – clean panels, no patchwork needed
  • Frame professionally blasted and coated – solid and ready to go
  • Converted to a full convertible using a ’74 removable top
  • New GM 350 crate motor (rated 350 HP)
  • New GM serpentine setup with all accessories
  • Monster TH400 transmission (new)
  • Aluminum radiator
  • New core support
  • Custom roll cage already installed
  • Skyjacker 6" lift (new)
  • 4.10 gears front and rear
  • 35x12.50s on American Racing wheels
  • Where It’s At:
    Truck is at the stage where it needs paint and final assembly. All parts are there and go with it. No rust repair, no drivetrain swap, no suspension work needed — just finish it how you want.
    Would make a great beach cruiser, trail rig, or clean squarebody build depending on your direction.
    If you know K5s, you know how hard it is to find one this clean to start with.
    $15,000.00
Wish you were closer I would take a look at this.
Damn. I’d love to have this. I want to go full convertible but couldnt bring myself to go through with it. I have in-laws in fredrick too.
Bump for you
