Herb S
Registered Member
OK I am new, I have a 1986 k10 suburban 350 carb. When I first start it the idle fluctuates till it runs for awhile. Has the auto choke on it. Then once she warms up and idles down vibrates in park and at stops, give it alittle gas and it smoothes out, but if you nail it it will hesitate. Shifts fine normale driving, but when you try to get on it alittle heitates before kicking down. Is this a fuel pump/filter problem, or maybe carb? Also what is the max tire I can put under it without lifting? Has 31 105 R15 now but they just don't fill the hole enough for me.
and a liberal douching with carb cleaner.. to make sure all the linkage is working correctly, accelerator pump, throttle plates, etc..
