LA 1986 Turbo K5
5.3okasai
Registered Member
Lake Charles, LA
1986 K5
Engine
• Stock 5.3 crank and rods. Pistons came from a 4.8, as you can see they are now flattop instead of dished.
• Clevite crankshaft and rod bearings.
• Durabond cam bearings
• ARP rod bolts and Brian Tooley head studs.
• Z06 camshaft
• LS9 headgaskets
• LS7 lifters
• TSP hardened pushrods
• Brian Tooley dual valvesprings
• New TSP oil pump
• LS6 timing chain
• 340 Aeromotive Stealth Fuel pump intank
• ½ fuel lines
• 60lb Siemens injectors
• Mallory fuel regulator
• Mighty Mouse catch can
• GT45 Turbo
• JGS BOV and wastegate
• A/A intercooler
• 3” s/s intake piping
• 4” downpipe w/ Dynomax bullet
• Speed density tuned
New radiator w/ electric fans
Transmission
4L80E
• Rebuilt by Jake’s Performance transmission
• 2800 stall
• B&M deep pan
• B&M transmission cooler with aux. fan
• Fresh rebuild on NP208 transfer case
Axles
• 14B semi-floating axle in rear
o 3.73 gears
o Gov-lock
o Dutchman custom 6 lug axles
o Lugnut 4x4 custom disc brakes
o Blue Torch Fabrication diff cover
• Stock 10 bolt up front for now
Wheels/Tires/Suspension
• 15” Rally wheels
• 33x12.50 Firestone destination A/T
• 2” lift w/ Bilstein shocks
Interior
• 2012 Mustang GT seats
• Helicopter seat belts front and rear
• Custom roll cage
• Rubber form fitted floors
• Dakota digital VHX instrument cluster
Exterior
• Softopper soft top “money well spent”
• Truck tailgate
• N-Fab steps
• Exterior is mostly stock, few rock chips here and there
16K OBO or open to reasonable trades
I can send many other pictures of the build.
call or text (337) 496-9158
K5 is located in Lake Charles, LA
Sweet looking truck. I'll make a suggestion to you though. Pull your turbo motor out and run it in your stang. Take a freshened up 5.3 or 6.0 and throw it in there.
Thats a 10-13k truck all day for the lower/medium buyers market but its a market where you'll be hard pressed to find someone willing to spend 4k more because its got a turbo setup.
Just some constructive advise!
I've thought about it, but I already have another LS waiting to be dropped in the mustang. Just would like to sell the K5 to make the build go by faster. Open to trades also.
So fricken awesome.
That's just awesome.
How high are you running the boost?
What kind of power is it putting down?
Honestly the turbo setup attracts me to this more than anything, but yeah its out of my price range I think.
Very clean build man. Well done.
Holy badassness! That is the coolest sleeper ever! Very clean work.
gotta love an LS Mustang swap.... best way to make a Ford run!
Awesome work on the Blazer!
