Greetings to all Chevy truck owners. Here is an interesting problem I am having with my 1987 Suburban. Ready for THIS engine issue?? I can hook up a Snap On MT2500 scanner to the ALDL plug and when I plug in the 12 volt accessory plug to power the scanner, the idle speed will S L O W L Y increase about 150 RPM. When I shift into ANY gear range (NOT Park or Neutral) and hold the brake, the rpm starts to increase more and I can hear the IAC opening up, ONLY WHEN THE SCANNER 12 lead is plugged in). I worked on these early systems and have the factory Chevrolet manuals on it with the wiring diagrams and it has kicked my butt!! I tried the other 12 volt lead I have with a gator clip directly to the battery positive, no change. My original problem was the old IAC was not working right and changed it with a new one (Standard Ignition Part Brand). My vacuum is at 22 inches and STEADY as a rock. I tried a second IAC and still no change. The EGR was changed last year and I have disconnected all the sensors and it STILL does it. I put the scanner on another vehicle, a 1994 Silverado and the scanner works flawlessly. ANYTIME I EVER had a problem with a scanner (The old TECH 1's) on the early TBI units doing this was a ground wire somewhere on the engine (Two on the front of the engine alternator bracket and two on the right rear of the cylinder head) either cut, loose or corroded. Nope, I found them ALL and they are nice and clean and tight, and even run extra ground wires to the body, frame AND engine...still NO CHANGE. BUT, the one strange issue I found was the black/white stripe wire in the back of the ALDL connector that goes to ENGINE GROUND is reading 56.7 ohms using a Fluke 77 DVOM meter. Ok, so just run an extra ground wire piggybacked to make sure it's grounded and it should work.....right?? NOPE, still does it. I do NOT like putting on parts to just (Try and see if it works), so I really don't have too many options left. I fully restored the vehicle so the fuel pump, pump relay, EGR, EGR solenoid, battery, cables, even an ECM was changed and STILL it has issues AND there are NO trouble codes. I know with as many wiring harnesses I have repaired/replaced in 30 years on the workroom floor as an automotive technician, this sounds electrical..........I still say a ground problem but what in the world have I overlooked??? I got so aggravated after pulling the dash out again that I just closed the garage door said "Another day ole' Mr. Burb".
