Hello,I have a 1987 Chevy 1 ton work truck that has 350 TBI and i am having problems,over the year when i would crank it up and go down the road it would surge alittle but would clear up i a minute or so,well this morning i went to crank it up it cranked fine but started surging up and down and gets worse,when i try to give it gas it will die,but it will crank back up but as it trys to warm up it gets worse and shuts off,i was reading on this site and tried a few things,I took off the vacume line to EGR and sucked on it and it would not pull air so i guess fine,i tried to pull a code but it did not have one stored,anyway dont know which way i need to go from here,on the TBI standing at front looking left theres 2 items on the throttle body are they the IAC and throttle position sensor?,one has 3 wires other has 4 wires with a square plug and its in the back,..also the truck is stock...thanks eric
