1987 Chevy cab and chassis one ton
mudmobeeler
Oklahoma
87 cab and chassis one ton dually. $2500 or best resonable offer. I lost the title while moving. Trying to get that sorted out before selling so that it will be a titled vehicle. Money is holding me up a little so it may be a little bit before i get it. Trying to speed that process up everyday though. Low mileage fuel inj 454, can't prove the low mileage so take that as you want. Has tons of power. SM465 four speed, works but has popped out of gear before when it was under a load. Seems like it was a lower gear but I can't remember for sure. 205 transfer case, Dana 60 front, FF 14 bolt rear cab and chassis dually axle. No bed on the truck, had a flatbed but previous owner kept it. Front 60 needs rebuilt, I know the pinon bearings are gone. I have another front end that I am trying to get the time to swap it in to give the truck 4x4 again and I would keep the bad front end. Heat and air worked great last I checked. Could use a battery. Was a manual window and locks truck, PO swapped on power doors so they are not the same color. Has small decents in the doors that possibly could be popped out from the inside. Have not found any rust except for the inner fenders and if I rem right they aren't through yet. Tires have held air for the two or three years I have owned it but I would think about replacing them if I were to drive it on the road. I've just driven it around my place. Needs a clutch master cyl or the clip that holds the rod in the master cyl. Haven't looked for that clip anywhere except new and you have to buy the whole master cyl which was around $30 if I rem right. Also needs slave cyl for clutch as the rod that pushes on the fork for the throw out bearing barely pushes on it. It is external slave cyl. It was roughly $30 also if I rem right.
Don't really want to sell but need the money. Hoping for a quick sell.
