Due to health issues, mainly back and hip, and that other thing.....oh, memory, I'm going to offer my K5 to the Brotherhood first. If not sold here I'll put it on FB Marketplace sooner or later.
1987 K5 Blazer
1999 454 Vortec......rebuilt Sept. 2017. Still needs break-in.
1999 4L80E.....rebuilt July 2017.
Dana 60 front......Trac-Lok limited slip
14BFF rear.....Detroit...Crane cover. Shaved off 1 1/2".
Rear Disc brakes......Caddy Calipers
5:13 gears
NP241 w/SYE
Tom Woods Shafts....Front and Rear.
ORD 4 link suspension. Front and Rear. King shocks with springs. 4" Bump Stops
ORD Steering Box Braces
ORD Hydraulic Assist.....PSC kit
ORD Heavy Duty Tie Rod
DIY4X basic roll cage kit
DIY4X Rock Sliders
Sanderson Headers....ceramic coated.
Stainless Steel Dual Exhaust. No cat
Viair On Board Air
TrailReady Beadlocks. 17x8.5 3.5" backspace. 5 total. 1 is for the spare, no tire.
Maxxis Crawlers. 40x13.5x17LT. Less than 50 miles
Auto Meter Gauges
Dual Batteries with ACR w/switch
A/C......Compressor and Lines not installed.
Warn VR 12,000....Wired and Wireless remote.
Extras:
Rear Quarter Panels RH+LH
Rear Floor Panels
Replacement Wing Windows....Used in great shape
Sliding Glass Window Frames.
Sliding Glass Windows.....Tinted
Sliding Glass Window Latch Kit
Sliding Glass Window Wing Kit to repair old swivels.
Lots of parts from the first build when it had the TBI 350.
I have both front seats and the rear seat. Driver side has tear on left side.
I also have 2 other front seats that are blue and no tears.
I was planning on putting on a Soft Top so all the guts are removed from the tailgate. I have all those guts and the glass.
Edit 9/1/23......I installed all internals of the tailgate.....Power Rear Window works like it should.
The PCM is sitting on top of the engine. It is only there temporarily. I plan to move it to the inside of the cab.
Edit 8/8/23......PCM has been moved to inside the cab behind the glove box door.
208 Team Motorsports did the harness and they did a great job. Once the engine is broken in it will need a final tune.
Edit 8/8/23.......Engine has gone through the break-in process. Taking it to have the final tune on the PCM.
Asking $20,000 for everything. OBO Hit the right number and it's sold. Wink Wink
1987 K5 Blazer
5:13 gears
NP241 w/SYE
DIY4X Rock Sliders
Viair On Board Air
Auto Meter Gauges
Extras:
Rear Floor Panels
