For sale is a White on blue 1987 Chevrolet K5 Blazer with 75,257 original miles. It is a 5.7L TBI fuel injected V8, 4-wheel drive, THM 700R4 transmission.
Asking $15,900
This truck is by no means a show car; solid frame, some rust in the rocker panels, bed floor, fender liners, and a previous repair of the rear quarter panels need redone (see pictures) but it runs very well and is a fun summer driver.
Clean car fax. Clear title.
VIN: 1GNEV18K0HF120786
More Photos here: SHARED - Blazer Photos - Oct26
Recent work (2025), including;
•New welded in front / rear floor pans
•New dual exhaust and mufflers (manifold back)
•New carpet
•New O2 sensor
•Tune up
•New battery
Other improvements
•Aluminum 17” wheels & 32” General Grabber AT2 tires (less than 1k miles on tires)
•Softtopper soft top AND factory hardtop
•Recovered seats
•All new exterior lights (side marker, taillights, front blinker lights)
•New exterior trim, emblems, etc.
•Spare tire and jack
•Much new sheet metal (door skins, front fenders, hood all replaced before I owned the truck in 2015) as well as an exterior respray
•Rebuilt transmission in 2012
•WARN manual locking hubs
•Trailer hitch
Truck is located in Cleveland, OH.
Original RPO Codes:
CV10516
AJ1 WINDOW TINTED, DEEP, ALL EXCEPT W/S AND DRS
AM7 SEAT, RR, FLDG
AV5 SEAT, FRT BKT, HIGH BACK
A33 WINDOW, POWER OPERATED, T/GATE OR BACK DR
B3W
B30 COVERING, FLOOR CARPET
CD4 WIPER SYSTEM WINDSHIELD, PULSE
CMD PLANT CODE, FLINT MI
C5M GVW RATING, 6100 LBS
C60 HVAC SYSTEM, AIR CONDITIONER FRT MAN CONTROLS
D1V GEAR, SPEEDO DRIVEN
D44 MIRROR O/S, PAINTED
E5Z SPEEDOMETER ADAPTER (DELETE)
E6D COUNTRY GAZA
E9Z SPEEDOMETER KEY (DELETE)
GT4 AXLE REAR, 3.73 RATIO (DUP WITH 5 X 1)
G80 AXLE POSITRACTION, LIMITED SLIP
JB5 BRAKE, POWER, DISC/DRUM, 6400 LBS
KC4 COOLING SYSTEM, HEAVY DUTY ENGINE OIL
K19 REACTOR SYSTEM, AIR INJECTION
K22 GENERATOR, 94 AMP
L05 ENGINE, GAS, B CYL, 5.7L, 1 TBI, V8
MD8 TRANSMISSION, AUTO 4 SPD, THM 700 R4
MX0 MERCHANDISED, TRANS, AUTO PROVISIONS, O/D
NA1 EMISSION SYSTEM, GVW, LESS THAN 8500 LB
NA5 EMISSION SYSTEM, FEDERAL, TIER O
NK7 FUEL TANK, 117L, 31 GAL
N33 STEERING COLUMN, TILT TYPE
N41 STEERING, POWER, VARIABLE RATIO
PA6 WHEEL, STYLED, PAINTED
SLM STOCK ORDER, PROCESSING CODE
UN9 RADIO, SUPPRESSION EQUIPMENT
UP7 RADIO PROVISIONS, FOR MONO INSTRUMENTATION
UY7 WIRING HARNESS, TRUCK TRAILER HD
U37 LIGHTER CIGARETTE
U69 RADIO, AM/FM, MTR
U76 ANTENNA, WINDSHIELD, RADIO
VR4 TRAILER HITCH, WEIGHT DISTRIBUTING PLATFORM
V02 RADIATOR, HEAVY DUTY, WITH TRANS OIL COOLER
V73 VEHICLE STATEMENT, USA/CANADA
XUY
X6Z HUB, LOCKING AUTOMATIC
YD3 FRONT AXLE, BASE EQUIPMENT FOR SCHEDULING, GVW PLATE
YD5 BASE FRONT SPRING
YD6 REAR SPRING, BASE EQUIPMENT
YUY Tires, Rear, off road, 31”x10.50R15LT/B
ZUY Tires, Front, off road, 31”x10.50R15LT/B
ZW9 BASE BODY AND CHASSIS
ZY1 COLOR COMBINATION, SOLID
Z53 CLUSTER, INST, OIL, COOL, TEMP, VOLTS
Z82 TRAILERING EQUIPMENT; CHEVROLET COLORADO
12K AUX TOP COLOR WHITE (91)
Asking $15,900
•New carpet
•New O2 sensor
•Tune up
•New battery
Other improvements
•Recovered seats
•Trailer hitch
Original RPO Codes:
CV10516
AM7 SEAT, RR, FLDG
B3W
E6D COUNTRY GAZA
XUY
