You can use a brass adapter from the hardware store.. 1/4NPT female to a flare male fitting.. The knock sensor will screw into the pipe thread female side, and the male side of that adapter you can wrap some tefelon tape around it and thread it into the hole on the drivers side of the block for the manual clutch linkage assembly to bolt to.. that is if you're running and auto.
The hole isn't the same thread but with some tefelon tape it will thread in tight.
