I did do a lot of fab work in the front end. I bought these axles for a jeep and did not use them, so I thought it would be easy. I started out was going to use a np265 transfer
case, which I bought. Then with my lift I needed a double cardan joint and the 265 can not be converted to a fixed yoke. So I went with the Atlas$$$$ Cheaper rout should have stayed with the np218 that I rebuilt and also found the 32 input spline that is discontinued that would work with 4L80. Long story, but I like a challenge, and the suspension is all finished. It's probably going to ride rough as crap, but it looks good and different. I don't think there is very many driver's drop k5 out there As for the traction bar I had the material so I am going to see how that helps the handling. And then I purchased a 1978 Blazer for parts with a np205 witch is what I wanted to begin with.
Installed leather interior and power AMP running boards Also installed stainless exhaust with electric cut-outs Getting close hope to finish interior this weekend.
