I messed up
It was the double scrader valves that messed me up. I removed the one that came with the drier, re vacuumed and gas started going in fast, cans got real cold!
However,
the reason my a/c originally failed was the high pressure line going from the condenser to the evaporator broke somehow. Not finding a replacement I took it to a hydraulic hose repair ship and they "fixed" it.
When I started adding R134a after removing the EXTRA scrader valve, Gas started escaping from the "repaired" line fitting. On checking I found that they repaired it using a smaller piece of pipe.
Since then I found that LMC had a replacement all along and I ordered it.
BUT, I did not know about replacing the pressure switch. Duh...
now how do I find the part number for a pressure switch that is for 134a ?
During my search for the part number I found this page, very interesting
http://www.e38.org/pparish/gm-rp.htm
So, I found part number, it is
Four Seasons part 36674... it turns off at 21 PSI and turns on at 42 psi. Per various ads it will fit my 1988 K5. around 18 bucks!
